2001 Chrysler PT Cruiser RAC & PINION
2001 CHRYSLER PT CRUISER
JACKSHER
Steering problem
2001 Chrysler PT Cruiser 4 cyl Front Wheel Drive Automatic
I HAVE INSTALLED 3 RAC & PINION UNITS AND 2 POWER STEERING PUMPS (ALL NEW) & ALL NEW HOSES AND IT STILL ACTS LIKE EITHER THE RAC OR PUMP IS BAD. I AM SO FRUSTRATED WITH THE SITUATION. IS THERE ANYTHING I AM MISSING? IT WILL NOT STEER. IT ACTS LIKE I AM TRYING TO STEER IT ON 2 FLAT TIRES. PLEASE HELP........
THANK YOU.
Oct 16, 2008 at 5:50 PM
BMRFIXIT
  • 19,053 POSTS
We had a ford did the same
after replacing ball joint and every little part in the steering system end up being the steering column
u joint was frozen
u may wants to check it out
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
bleed the system
Oct 16, 2008 at 8:25 PM
