Yep, GREAT explanation of VERY confusing systems for an ol' shade tree mechanic to get, Car Doc.
Doc, I FINALLY got it on a diagnosis machine. He did all the standing checks, used his little tablet to play with the idle, check ALL the systems and told me what I already suspect. I had unhooked the battery the AC need servicing and there were NO CODES. LOL
So, he and his computer took a test drive. Again, NO engine codes. The way it was acting made him suspect it's a transmission problem. So he stopped and reset it to quick learn and drove it again recording the data points. The ONLY code he got at all for ANYthing that seemed out of place was that it SAYS that the overdrive clutch is engaged all the time? What!?!?
Anyway, he said that all he could think of was that MAYbe the overdrive clutches have stuck together from carbon build up or something...kind of like the clutch packs in Ford rear ends tend to do and cause that infamous clunk going around corners. So, he sent me up the road to a friend who has 45 years experience in transmission repair.
By the way, the mechanic spent an hour an a half tinkering with the little car and didn't charge me a DIME. And I TRIED to get him to let me pay him for his time. He said, "Nope, I don't charge if I can't fix it." Cool to find principled mechanics these days. ;~)
ANYway, I went up to the transmission shop and the owner took her for a drive. He came back and said, "Their ain't SHITE wrong with that transmission."
He's kind of a surly ol' boy and shite ain't the exact word he used, but you get the point. LOL
Anyway, he said I've seen this with a LOT of different cars and it's the catalytic converter. WHICH, I've gotta say is something I've suspected from the start. He didn't even bother hooking it up to his computer. He said flat out, replace the converter and it will run like a Deer. As in John Deer of course. Did I mention I'm in a rural area?
At any rate, I asked if it wasn't trowing a code because the O2 sensor was working fine and it was just a software conflict between the actual air flow and the computed air flow that's causing all these symptoms, to which he said, "Yep, I've seen it a bunch." Then he repeated, "Replace the converter and it'll run like a Deer."
A question for you Car Doc. Does that make sense to you? As I said, I've suspected the converter from the beginning, but this computer stuff is WAY above my pay grade. I didn't and STILL DON'T have a clue how all this computer stuff interacts and what symptoms can be induced by the computer module because of faulty readings.
What say you Doc? I hate to pay 300 bucks for a converter and end up with a trashed transmission to deal with anyway. Ya know?
And thanks again for hanging with me on this. I'm sure you've got better things to do, so I really do appreciate your feedback!
Mar 10, 2019 at 11:09 AM
(Merged)
