Brakes problem
2001 Chrysler PT Cruiser 4 cyl Front Wheel Drive Manual
i recently changed my rotors and i had also changed my drivers side brake line (from wheel cylinder to steel tubing before the reservoir) and i did not change the pads. when i start the car my brakes are not there. brakes push way too easy. i dont see the bleeder screw but i did try bleeding them by the screw that ataches the brake line to wheel cylinder(since there is a hole in screw to allow fluid to pass) which when brakes were pushed fluid gushed from the hole. i am out of ideas please help.
Sep 13, 2010 at 7:05 PM
