2001 Chrysler PT Cruiser head gasket oil leak
2001 CHRYSLER PT CRUISER
74,000 MILES • 4 CYL • 2WD • AUTOMATIC
I hear this is a common problem on the PT Cruiser. But just wondering if having my cam shaft seal replaced could encourage the leak to happen? It was right after I had my cam shaft seal and timing belt replaced that my head gasket began leaking oil... Just a coincidence?
Apr 24, 2009 at 7:18 PM
It was right after I had my cam shaft seal and timing belt replaced that my head gasket began leaking oil... Try retorquing the head might work. If it continues to leak the head could be warped that's if its actually leaking between the head and block
Apr 24, 2009 at 7:32 PM
