oil consumption
CHRYSLER PACIFICA
SWIMMINGLY
My 2005 pacifica recently started consuming roughly 1 quart of oil every 2,000-3,000 miles. It got drastically low back in June between oil changes and the techs told me I was down to less than a quart of oil. At that time, I had a noisy engine, but I never had any indicator lights that I was hot, or low in oil. The mechanics told me they thought the cause was that at my last oil change (not done by them) they didn't put enough oil in the car.
Well, now one month later it is still doing the same thing, I have been very careful about checking it now that I am suspicious about it. This car has 36, 100 miles on it. It is not leaking, nor do I consistently see smokey exhaust, although I have seen it rarely right after I start it up and it idles for a few minutes.
Do you have any ideas on what could cause this? If it is not fixed, is there any long term damage that can be done to the engine due to this consumption of oil?
Jul 24, 2007 at 2:25 PM
2CARPRO JACK
  • 11,533 POSTS
Could be valve stem seals or valve guides.If not taken care of over time you will get a carbon build-up in the combustion chambers that will lead to detonation problems
Jul 25, 2007 at 7:48 AM
SWIMMINGLY
I am being told by my dealer that burning 1 quart every 950- 1250 miles is acceptable according to their "specs". They are also telling me that this will not damage my engine in any way. They say that with the design of the engine the chambers don't fully clear the oil and it burns off. I do not believe this is acceptable. I think it will cause damage, like the damage you previously stated. Do you agree?
Jul 25, 2007 at 4:51 PM
2CARPRO JACK
  • 11,533 POSTS
Sounds like some back-peddling going on there.That much oil consumption in my opinion isnt acceptable in any vehicle
Jul 25, 2007 at 5:56 PM
