Engine Cooling problem 6 cyl Two Wheel Drive Automatic 97k miles
changed the water pump and timing belt thinking the water pump was what was leaking. after changing still have the leak. only leaks while sitting overnight. does not leak while running. leaking through a big cast opening hole which looks like it was designed to tell you what was leaking. 3.5liter
don't know what to check now.
Jul 16, 2008 at 8:32 AM
