2006 Chrysler Pacifica Changing headlight bulbs
2006 CHRYSLER PACIFICA
30,000 MILES • 6 CYL • 2WD • AUTOMATIC
BILLV1
I am trying to improve the brightness of the front headlights by changing from std. bulbs to silverstar bulbs. To do this I have to remove the front lenses. following the instructions I should be able to remove two screws from the top of each lens and pull out the lens to get at the bulbs. I did tnis but experenced significant resistance like there is another clip to release. I do not want to break the lenses. Do you have some advice on how to get these lenses out? I live in NH where it is pretty cold now.
Thanks
Dec 9, 2008 at 10:40 AM
GEORGE DOE
  • 10 POSTS
Yes there is a clip at the bottom center of the headlight. When the 2 scrwes are out grab the light from the bottom center and pull up and out at the same time. You try this and it will snap off easy for you. Don't forget that when you put it back in that the clip is the first part you snap into place , and then the blots
Dec 19, 2008 at 9:16 AM
