2006 Chrysler Pacifica alternator
2006 CHRYSLER PACIFICA
105,000 MILES • 6 CYL • FWD • AUTOMATIC
CINDYNANA
I need to know the easiest way to change the alternator and is there any special tool I need?
Oct 1, 2010 at 10:52 PM
There is no easiest way but the right way to do it-see procedures below: REMOVAL Disconnect battery negative cable. Remove the engine cover. Remove the generator drive belt. Positive Battery Cable And Field Connector
https://www.2carpros.com/forum/automotive_pictures/12900_a1_22.jpg
Remove the B+ terminal nut and wire. Disconnect the generator field circuit wiring connector. Push the RED locking tab to release. Upper Mounting Bracket
https://www.2carpros.com/forum/automotive_pictures/12900_a2_22.jpg
Remove the upper mounting bracket. Generator
https://www.2carpros.com/forum/automotive_pictures/12900_a3_2.jpg
Remove the 2 lower mounting bolts. Remove generator. INSTALLATION Install generator. Generator
Install the 2 lower mounting bolts. Upper Mounting Bracket
Install the upper mounting bracket. Tighten the 2 lower bolts first, tighten bolts to 54.2 N.m (40 ft. lbs.) then tighten the 2 upper bolts, tighten bolts to 28.2 N.m (20.8 ft. lbs.) . Positive Battery Cable And Field Connector
Connect the generator field circuit wiring connector. Push the RED locking tab to lock connector. Install the B+ terminal nut and wire making sure the terminal is properly oriented with the anti-rotation tab. Tighten nut to 12.5 N.m (110 in. lbs.) . Install the generator drive belt. Install the engine cover. Connect battery negative cable. https://www.2carpros.com/kpages/auto_repair_manuals_alldata.htm
Oct 3, 2010 at 8:03 AM
JAMBERS87
Are there any other alternators that will interchange with a 2005 Chrysler Pacifica 3.8 liter?
Dec 6, 2021 at 12:14 PM
That's a tough question to answer because there are different alternators for the same vehicle. It's based on options and alternator output needed.
If you have a specific vehicle with a replacement alternator, I can check to see if the part numbers cross. Just let me know the specifics.
Let me know. Also, have you confirmed the alternator is the issue in this case? The regulator is an internal component in the powertrain control module.
I'll watch for your reply.
Dec 8, 2021 at 7:45 PM
