I turn steering wheel slightly right a loud thumping?
2005 CHRYSLER PACIFICA
47,800 MILES • 6 CYL • 4WD • AUTOMATIC
PATTYM64
When I turn steering wheel ever so slightly to the right there a loud thumping noise. If I make a full turn to the left or right no problem. Just when I turn half inch or so to right. What could it be?
Nov 30, 2009 at 3:34 PM
SQM
  • 6,383 POSTS
There could be several factors for a suspension noise.
It could be the tie rod end makes that noise. Also the CV shaft can trigger noise if it is loose.
First do a visual inspection of the front suspension. Look for any damaged or broken components.
Go thru this article it mentions the typical issues that could make that noise.
https://www.2carpros.com/articles/popping-noise
Let me know of any questions.
Thank you.
Sep 2, 2021 at 11:51 AM
