I would like to change my automatic trans filter and oil
2004 CHRYSLER PACIFICA
DAVEHMB
I would like to change my Pacifica Auto trans filter/oil. I already know about the majority of the oil being in the torque converter but the question is: Do I really have to jack the engine up a bit to drop the pan and get the filter out? It looks like there is enough clearance but if the filter hangs down a bit than I can see it hitting the frame, maybe. I don't want to get have way through and then realize that I do have to loosen the two bolts (or remove them) and jack the engine up which would be a real pain for me. (note: the service manual words it like it may be an option for ease of removal)
Comments?
Apr 13, 2008 at 6:54 PM
SQM
  • 6,383 POSTS
It is recommended that you take off the engine mount bolts and tilt it up to give you enough room.
When you do a drain and fill, you should need about 4 QT of ATF+4 transmission fluid.
I would recommend catching the used fluid in a container that you can measure, this will take any guess work out of how much fluid you might need.
Here is a helpful article:
I have attached the diagrams for your reference.
Thank you.
Sep 16, 2021 at 9:07 PM
