Idle Air Control
CHRYSLER
ROADRUNNER118
  • 14 POSTS
[b:4790a912bf]1995 checy silverado, 130,000 miles, I have fast idling most times, recently replaced the IAC valve, fault code 35 still reappeared and problem continued. Question, should I replace the IAC again or are there other any other solutions?? [/b:4790a912bf]
Nov 26, 2006 at 12:31 AM
  • 131 POSTS
Make shure the throttle body is clean were the iac mounts up. Also make shure that the voltage signals are in spec, and are the same at the pcm and the sensor. If not it's in the wires. If it is then it is most likely in the pcm its self.
Dec 8, 2006 at 12:57 AM
