ABS Shimmy?
CHRYSLER
JOHN BENCICIK
96 GMC PU with ABS. When slowing down to stop, front end shakes like the old Shimmy. No brake or ABS warning lights, tire pressures equal and front end tight. Can this be warped disc? Have not had any other braking problems, wheel removals or changing of tires that may have caused uneven tightning of lugs.
Feb 11, 2006 at 3:20 PM
PEPPERMRJ
  • 1,158 POSTS
You will get better results posting in the correct forum.
Warped disc can cause problems. Do you fel a pulsation in the pedal?
Feb 12, 2006 at 10:37 AM
JOHN BENCICIK
[quote:ed496db3b5="peppermrj"]You will get better results posting in the correct forum.
Warped disc can cause problems. Do you fel a pulsation in the pedal?[/quote:ed496db3b5]
Sorry - clicked wrong forum
Very little pulsation in pedal - some in steering wheel.
Seems more like whole front end is shaking. Also, may be less noticable in very cold weather.
Feb 12, 2006 at 10:58 AM
PEPPERMRJ
  • 1,158 POSTS
Might try rotating the tires.
Feb 12, 2006 at 11:00 AM
