1997 Other Chrysler Models wont shift
1997 CHRYSLER
APLOM09
Transmission problem
1997 Other Chrysler Models 6 cyl Front Wheel Drive Automatic
vehicle speed sensor malfuntion/codes and powertrain control modular/codes and speed oometer dont work
Jul 22, 2009 at 11:15 PM
CH112063
  • 1,320 POSTS
If you are asking what you should do if you have a speed sensor failure code from your powertrain control module the correct procedure would be to check the connector and wiring for open or shorted circuits, be sure that you have a proper feference signal and ground, then you would come to the replace speed sensor step, get a new one (Mopar) and replace it. That should do it. It is a very common failure because it is a high wear item. If you have a different question just ask. ok
Sep 7, 2009 at 9:31 PM
