1968 Chrysler Newport Cars absolutely dead no power.
1968 CHRYSLER NEWPORT
133,000 MILES • V8 • 2WD • AUTOMATIC
SGNRULZ
Its not the battery.
if you run hot to hot on the starter relay the car cranks.
There is no headlights no interior lights no nothing.
But the horn works.
Im stumped to what it is.
Fusable link maybe?
If it was the ballast resistor id still have lights right?
Jan 12, 2010 at 11:25 AM
Check and test all the fusible links, neutral safety switch and ignitiion switch-Ballast resistor is for your ignition system
Jan 12, 2010 at 2:02 PM
MEGAN WRIGHT
  • 0 POST
I do not think it is because of the fusable link. I think there may be some short circuit inside the car engine. So I suggest it is better to concern a good car repair center rather than doing much more experiment with it. Because if small problem do not get enough care then it may lead to a big one and have to face large problems which is not acceptable. So, to avoid the same we have top go for a good repair center to us and have to get our car repaired to stay away from many more car related issues like car crash and car accidents which also may result from the problem mentioned above.
Dec 18, 2013 at 2:18 AM
GEORGEGNN
  • 0 POST
Maybe you have some sort of electrical short somewhere between the battery and the ignition switch. To find out the real cause of problem bring your car to a certified auto technician. That’s the only way to identify the problem and get it solved.
Nov 6, 2014 at 11:26 AM
VASKEN90254
  • 0 POST
Have you tried checking the fusable link? I believe it has something to do with your car’s fusable link. The next time you aren’t sure what is the cause of your car’s problem, you’d better call or visit the nearest Automotive Repair Center near you or the one that specializing your car’s make. It’s better to have them check your car than guessing and repair it on your own. It might cause more trouble after.
Nov 22, 2014 at 11:34 PM
