87 Chrylser New Yorker Having Problems
1987 CHRYSLER NEW YORKER
JNTMLESS
I have an 87 Chrysler New Yorker with 100,000 miles. The car is automatic with a 2.5L engine.
The car has become difficult to start. A few days ago, the "Power Loss" light came on while I was driving. I drove home and parked the car for a few hours, but when I tried to start it again, it wouldn't start. I added gas and the car started. The next day on the way home from work, I noticed white smoke coming from the exhaust. I stopped to check it and noticed it had an unusual odor(I associated it with either radiator fluid or brake fluid - maybe mistakenly). I checked the fluid levels, which were both a little low, but figured with the white smoke, I had a head gasket leak. The car was difficult to start but once it got started, still ran great. Yesterday I replaced the head gasket and the car started immediately. But after I shut is down to adjust the tension on the belts it wouldn't start again. Also, the exhaust has the same smoke and odor. What is going on?
May 28, 2007 at 9:29 AM
DEREK BRICHACEK
  • 11 POSTS
um white smoke can sometimes be old oil or mabe some one put something in your gas tank the batterie light is kinda odd i dont know why that would happen
Jun 8, 2007 at 3:34 PM
WAR SIGMA
I had the same problem, check your pumps and gaskets, just after i had smoke everything started to go on the car,and my water pump no longer works...so my advise.. check that and check for other potential leaks. a clear sign thattheres moistuer of any kind is wetness under the tail pipe.
Jun 11, 2007 at 12:27 PM
