I have a 84 newyorker 2.2 turbo 32k miles
replaced parts and cleared all codes except 23 wich is the charge temp sensor oredered it came in but will not fit of corse
PROBLEM is if I turn left It falls on its face and or dies
acts as if its not getting fuel but it should
since then I have replaced all rubber fuel lines, pump, filter and checked presure regulator etc all is good until I turn left still
checked for wires to make sure I wasnt shorting something with steering components etc nothing I can see
at this piont im about to replace the fuel pump agian while it is still under warrenty
thought I would ask here who knows might think of somthing I have not
other things replaced on this car might not matter to issue logic module/distributor pickup/fan/radiator/coil/tp sensor
May 28, 2007 at 6:02 AM
