Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Chrysler
New Yorker
Ignition
Timing
1995 Chrysler New Yorker Timing
1995 CHRYSLER NEW YORKER
84,000 MILES • 6 CYL • FWD • AUTOMATIC
KEVIN37
MEMBER
1 POST
FOLLOW
How do you adjust the timing for this vehicle. Replaced the Water Pump and must have knocked the timing off as it will not start.
Sep 14, 2008 at 9:50 PM
CERTIFIED EXPERT
You probably didn't set the no.1 piston on its compression/TDC and align the timing sprockets when you remove the timing belt.
Check for spark and fuel-you got both you have to open it up again and redo it-
Sep 15, 2008 at 4:47 AM
