1994 Chrysler New Yorker high idle
1994 CHRYSLER NEW YORKER
104,000 MILES • 6 CYL • FWD • AUTOMATIC
BULLHEAD
when I start the car up after it is warmed up it idles at 1700 to 2000 rpm. that relates to about 35mph. could it be the o2 sensor or maybe the map sensor? the check engine light doesn't come on. if I pull the wiring conector off of the map sensor the idle goes down to about 800 rpm but the check engine light comes on. any ideas would be appreciated. thank you
Dec 20, 2007 at 10:44 AM
BMRFIXIT
  • 19,053 POSTS
[quote:de2aeb25a3="bullhead"]Engine problem
1994 Chrysler New Yorker 6 cyl Front Wheel Drive Automatic 104000 miles
when I start the car up after it is warmed up it idles at 1700 to 2000 rpm. that relates to about 35mph. could it be the o2 sensor or maybe the map sensor? the check engine light doesn't come on. if I pull the wiring conector off of the map sensor the idle goes down to about 800 rpm but the check engine light comes on. any ideas would be appreciated. thank you[/quote:de2aeb25a3]
check idle air and clean throttle body
check TPS volts
check for vacuum leak
Jan 3, 2008 at 8:59 PM
