I have a 1994 chrysler, it turns over really strong but will not start,I replaced the : crankshaft sensor, the fuel pump,the computer,the fuel pump relay, the ASD relay, also the fuel pump fuse is good, I put the old computer back in and put another camshaft sensor in and it started for about 1 minute then it quit, I then restarted it and it ran for about 30 seconds the it shut off, finally before I replaced the coil I double checked the crankshaft sensor wiggled the wires a little made sure it was plugged in completely and the I then got fire and the car almost started,so I replaced the coil and it started right away I drove it for 2 full days with no problems, then I got in to start it and it started doing the same thing I unplugged the wire harness to the coil and then plugged it back in the car started for about 2 minutes then it shut off again,I replaced the spark plugs and the wires it turns over strong but still will not start I will try to mess with the crankshaft sensor a little more is there anything you guys can suggest before I go to my last option and pay a huge bill on diagnostic tests. my email address is : [email protected]
Apr 1, 2009 at 9:52 PM
