1993 Chrysler New Yorker hot brakes
1993 CHRYSLER NEW YORKER
103,500 MILES • 6 CYL • FWD • AUTOMATIC
CDGADART
  • 4 POSTS
The car has new rotors, calipers, and pads on the front. The system has been bled. The problem is the front brakes are not releasing properly. Driving the car only a few miles and you end up with the brakes grabbing. Your car should coast when you take it out of gear but it comes to a stop and you can feel the heat and smell the brakes. I don't want to hurt the transmission so I am asking for a little help with this problem. Thanks for your help on this matter.
Dec 26, 2008 at 7:48 PM
Check the ABS unit if it has one-and check the brake hoses could be collasped internally acting as a one way check valve-
Dec 27, 2008 at 6:58 AM
CDGADART
  • 4 POSTS
The problem with my New Yorker ended up being the clamps that hold the rubber hose to the struts were rusted and corroded so bad that they pinched the hoses. I pried the clamps loose and the brake calipers release fine now. Thanks for the help rasmataz!!
Dec 31, 2008 at 12:36 PM
