Suddenly my Auto Temp control appears to be stuck in HEAT mode. When you select "auto" and select the lowest temp (65) the system stays in heat mode. The A/C compressor kicks in, but of course to no avail. Also, the air does not switch from floor to panel. HOWEVER, if you manually select panel, floor, def...the air flow will change. The temp stays hot. I have been told there is some "diagnostic" mode the dash panel can be set in to self diagnose, but have no idea if that is true or not. Any help or direction would be appriated.
May 8, 2009 at 5:31 PM
