1995 Chrysler Neon won't start
1995 CHRYSLER NEON
95,000 MILES • 4 CYL • 2WD • AUTOMATIC
FED
The engine cranks but won't start. The OBDII reader says it has a P1491 error code. I've change the ECM. Can the fan relay cause it not to start?
May 16, 2009 at 9:27 AM
MMPRINCE4000
  • 8,548 POSTS
It may be a failsafe built into the ECM so that you do not overheat the engine. But I would fix the error code.
If problem persists, check fuel pressure, if no pressure, then either the pump,relay,fuse, OR ignition system is not sending a spark reference pulse to ECM which will cause the ECM to shut fuel pump off.
May 16, 2009 at 9:37 AM
