Erratic rpm @ low speed
CHRYSLER LHS
IVAN355
  • 4 POSTS
Hello I have a 1996 Chrysler LHS with 180,000 klms, 3.5 engine.
The problem is at low speed coming to a stop the tack will drop to around 500 then surge to 1100-1200 rpm and almost stall.
This all started when the water pump and timing belt was changed. I have changed out the TPS, cam sensor and done a regular tune up with new plugs and wires.
The car has been in the shop and on a scanner with no codes issued. The mechanic did make some adjustments with the scanner and it did run better for a day.
The car runs worse in cold weather. Also when at a stop sometimes the car will idle low at about 600 rpm, but if you put it in neutral then back in drive it will be back to normal at 750.
Can anyone give me a clue on what this problem would be? Any help would be much appreciated.
Thank you in advance Ivan.
Mar 17, 2007 at 1:10 PM
[quote:3409a73d34="ivan355"]Hello I have a 1996 Chrysler LHS with 180,000 klms, 3.5 engine.
Thank you in advance Ivan.[/quote:3409a73d34]
Inspect and test the PCV valve and EGR systems and then comeback
Mar 17, 2007 at 3:52 PM
IVAN355
  • 4 POSTS
Hello thanks for the reply.
I have changed the pcv valve, I will run a check on the egr valve.
Mar 17, 2007 at 6:41 PM
IVAN355
  • 4 POSTS
As per your suggestion rasmatas over the weekend changed the PCV and tested the EGR valve. The PCV valve was a couple of months old but changed it anyway and the EGR valve tested good.
Also recharged the battery and found that it was down on liquid, checked the vacuum lines and found them all good.
Took the car for a couple of hundred klm run on Sunday and the problem still persisted. Not at every stop did it surge but at lest 50% of the time.
Would you have another suggestion to try?
Mar 19, 2007 at 4:25 AM
[quote:9405c684a4="ivan355"]As per your suggestion rasmatas over the weekend changed the PCV and tested the EGR valve. The PCV valve was a couple of months old but changed it anyway and the EGR valve tested good.
Thank you in advance Ivan.[/quote:9405c684a4]
Lets try cleaning out the throttle body/ISC or IACV and comeback.
Mar 19, 2007 at 6:01 AM
