All of the sudden my abs light came on my traction control doesn't work?
1997 CHRYSLER LHS
SCOTTYB79
all of the sudden my abs light came on my traction control doesn't work and my heater/ac is stuck at a low heat (it's digital and it doesn't show anything) when i tried to replace the burnt fuse for the heater it blew i've tried several fuses and they keep blowing
Jan 3, 2006 at 10:50 PM
You have a short circuit in the HVAC electrical system and a wheel speed sensor that needs to be replaced, Usually when the heater fuse pops the blower motor resistor or the motor itself needs to be replaced. Here is the location so you can swap them out which should fix the problem. Check out the images (below). Let us know how it goes
Jan 4, 2006 at 3:09 PM
