[quote:f4ec4d38f8="mtxmike"]Engine Mechanical problem
2001 Chrysler LHS 6 cyl Two Wheel Drive Automatic 100,00 miles
According to Chrysler, my Timing Belt broke this morning while I was driving 65mph down the freeway. It ran very hot, I pulled over right away, called a tow truck, and had it towed to Chrysler, and they are saying the cost is $1200.00, and they can't gaurantee that will fix the problem, what are my alternitives.
And Thank you In advance.
Mike[/quote:f4ec4d38f8]
Hi Mike,
Did your vehicle shut down while driving before pulling over? If not then I would say that it may not be the Timing Belt, cause your vehicle would have shut down as soon as it broke.
It is possible that the water pump has gone bad. And it is run by the Timing Belt. So, it would only make sense to change the Timing Components at the same time.
And of course the dealer is gonna be more expensive than if you call your local repair shops.
So, I would call around and inquire about your problem and then decide on which one you feel has been more truthful and have it taken to them for diagnosis.
Or if you are mechanically enclined we can assist in diagnosis by giving you places to start looking.
Apr 28, 2009 at 2:39 PM
