2.7L
Remove or disconnect the following:
Negative battery cable from the remote ground post
Battery feed and posi-lock connectors
Nuts from the catalyst support bracket and mount
Starter heat shield
3 starter-to-engine/transaxle bolts
Now remove starter by rotating it toward the engine and sliding it rearward between the catalyst and the engine mount
3.5L
Starter-to-engine/transaxle nut and bolts
Positive battery feed wire from the starter
Starter and position it to gain access to the posi-lock connector
Place a support under the engine and slightly relieve the pressure from the left engine mount.
Remove the 3 left engine mount-to-engine bolts.
Slightly, raise the engine to provide more room.
Remove the starter by sliding it rearward between the catalyst and the engine mount.
Remove the posi-lock connector.
Apr 28, 2010 at 8:40 PM
