1999 Chrysler LHS Alernator or Battery
1999 CHRYSLER LHS
45,000 MILES • 4 CYL • 2WD • AUTOMATIC
RONICRAZY
My car won't start. When I turn the ignition the lights go on, radio but it won't turn. It goes rrr- rrr- rrr-rrr. I checked the batter and received a 12.49 reading followed by a 12.53 after I tried to start the car. Is it the alternator? Starter? or the Battery? (i don't think its the battery). The cables are clean and she has a good connection. (wires are intact).
Jan 17, 2008 at 5:33 PM
MASTERTECHTIM
  • 4,750 POSTS
sounds like your battery. charge battery or try jump starting. just because you have 12 volts that does not mean it is putting out enough amperage. get back to us after you try jumping it. feedback is greatly appreciated
Jan 17, 2008 at 5:36 PM
BMRFIXIT
  • 19,053 POSTS
[quote:cf23af8526="ronicrazy"]Other Category problem
1999 Chrysler LHS 4 cyl Two Wheel Drive Automatic 45,000 miles
My car won't start. When I turn the ignition the lights go on, radio but it won't turn. It goes rrr- rrr- rrr-rrr. I checked the batter and received a 12.49 reading followed by a 12.53 after I tried to start the car. Is it the alternator? Starter? or the Battery? (i don't think its the battery). The cables are clean and she has a good connection. (wires are intact).[/quote:cf23af8526]
you need to check battery volts while cranking it should hold over 8.5 volts
if not battery no good
cant check alternator with car off
it has to be running with it running volts should be 14.5
the sound you describe (sounds to me)
battery low or check terminals
Jan 17, 2008 at 5:42 PM
