1997 Chrysler LHS Warm engine fails to start
1997 CHRYSLER LHS
165,000 MILES • 6 CYL • FWD • AUTOMATIC
The LHS had a gas leak and the dealer replaced the fuel rail. Now the car will start and run, but fails to restart after driving awhile. If the car sets for about 30 to 45 minutes it will start. Any suggestions what could be causing this problem?
Jan 12, 2008 at 7:18 PM
BMRFIXIT
  • 19,053 POSTS
[quote:fc9a985685="[email protected]"]Electrical problem
1997 Chrysler LHS 6 cyl Front Wheel Drive Automatic 165000 miles
The LHS had a gas leak and the dealer replaced the fuel rail. Now the car will start and run, but fails to restart after driving awhile. If the car sets for about 30 to 45 minutes it will start. Any suggestions what could be causing this problem?[/quote:fc9a985685]
crank sensor
check and or replace crank sensor
check relays
Jan 12, 2008 at 7:40 PM
Thank you for the quick response. I will let you know the results.
Jan 12, 2008 at 7:49 PM
