'97 Chrysler LHS 3.5L V6 120,500 miles.
When at a dead stop in drive or reverse, it idles rather rough (even throwing up a low oil pressure light a few times), around 600-650 RPMs. The problem is almost completely eliminated in neutral or park, but there is still a noticeable lack of a smooth idle.
It also has a bit of hesitation (feels as if you are pulling the slack out of a weighted rope) when starting out from a stop.
I checked the upper intake manifold for by spraying carb cleaner at each intake, but it produced no effects at all.
I regularly run injector/fuel system cleaner through the engine every 2,000 to 3,000 miles. I recently ran SeaFoam through it to see if that would help the idle, but I got nil.
There is no CEL and the only code is a number 12 (battery disconnected).
Mar 19, 2010 at 10:48 PM
