The fuel pump can be accessed via the trunk.If you lift the trunk carpet you will find an access panel just ahead of the well for the spare tire.I believe there are 4(four)nuts holding this panel down.NO NEED TO DROP THE TANK.
Another bit of advice.Get a Haynes manual for the car.It contains a lot of info.Should be about $15 - $17 at almost any auto parts store.
Hope this helps. Best regards,goonior.
Sep 15, 2007 at 12:16 AM
