1995 Chrysler LHS surge or miss at low speeds
1995 CHRYSLER LHS
LEANNIE62
Engine Mechanical problem
1995 Chrysler LHS 140000 miles
where would you suggest to start looking for the cause of a surge or miss at low speeds.
Nov 8, 2009 at 4:59 PM
Oxygen sensor
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Nov 8, 2009 at 5:01 PM
