Our rotors and pads are fine. The brake pedal operates too low or close to the floor and braking power is diminished. When we pump the brakes or put the transmission into neutral, however, the brake pedal is higher and there is greater braking power.
I will use your diagnostic info, for which I thank you, to inspect and, if necessary, replace the master cylinder and bleed the lines.
QUESTIONS: Before I do so, is there an issue related to the power braking system that I should look into?
Thanks again.
Thanks again.
Mar 31, 2009 at 11:22 AM
