1994 Chrysler LHS white smoke coming from exhaust
1994 CHRYSLER LHS
AKLEWIS100
  • 5 POSTS
Smells problem
1994 Chrysler LHS Two Wheel Drive Automatic 105000 miles
white smokes comes out of the exhaust even when the car is warmed up. the heat does not be on. so i was wondering what could the problem be so i can correct it
Feb 15, 2010 at 12:07 PM
DOCFIXIT
  • 18,828 POSTS
Check oil look normal? May have a failed intake or headgasket.
Feb 15, 2010 at 3:22 PM
AKLEWIS100
  • 5 POSTS
i have checked the oil and its fine no mikly substance i stay in detroit where it is cold as of now. i checked the oil cap and it shows no condensation at all.i have a trans leak thats coming from the coolant transline so could that be the problem?
Feb 15, 2010 at 4:12 PM
DOCFIXIT
  • 18,828 POSTS
Trans fluid leak is not related. The smoke is coolant entering cumbustion chamber if oil good then intake leak is fault. How often do you add coolant?
Feb 16, 2010 at 7:56 AM
AKLEWIS100
  • 5 POSTS
Oil is fine i have to add some probably every month and half
Feb 16, 2010 at 8:26 AM
