1994 Chrysler LHS No heat at idle
1994 CHRYSLER LHS
175,000 MILES • 6 CYL • FWD • AUTOMATIC
COADTY
I can run my car for quite a while and the temp guage reads heat available but no heat inside the car. When I put the vehicle into gear and drive for a short distance the heat suddenly is there. It comes then goes cold then gets hot and stays hot. It happens all the time. The vehicle doesn't overheat and the temp of the air inside the vehicle is hot.
Feb 27, 2008 at 4:15 PM
BMRFIXIT
  • 19,053 POSTS
check coolant level and adjust
your coolant level low
when engine cool open and check coolant
bleed system
Feb 27, 2008 at 7:54 PM
