1994 Chrysler LHS LIGHTING
1994 CHRYSLER LHS
GTO69
1994 Chrysler LHS
94 LHS HAS NO LOW BEAM HEAD LIGHTS,HAS HIGH BEAMS AND MARKER LIGHT,THE BULBS ARE GOOD,USED TO HAVE TO USE HIGH BEAM SWITCH TO GET LOW BEAMS TO WORK,THIS UNIT HAS AUTO HEAD LIGHT AND THEY WILL NOT WORK EITHER. ANY HELP PLEASE
THANKS GTO69
Aug 11, 2009 at 10:58 AM
JDL
  • 16,098 POSTS
Hello, my first thought was the dimmer switch. Check fuse L43--15 amp probably in the power distribution center under the hood. that fuse is between the dimmer switch and left headlamp, that is for low beam, not only check the fuse, use a testlite, check that the fuse circuit is hot with low beam. If that isn't hot, you need to backtrack to the dimmer switch.
Aug 11, 2009 at 11:46 AM
