1994 Chrysler LHS
1994 CHRYSLER LHS
R CHASE
1994 Chrysler LHS
can a bad vacuumhose make the engine overheat and also where would you specifically find it once you open the hood thanks so much
May 26, 2008 at 10:28 PM
BMRFIXIT
  • 19,053 POSTS
Thermostat , low coolant ,coolant leak , coolant fan , head gasket failure
those are the main cause for over heating
vacuum hose will not cause the engine to over heat it may cause engine to run rough and …
May 27, 2008 at 6:37 AM
