i own a 1992 lebaron 4 dr.
you'll have to undo all connections.... do this delicately, as the connections are very fussy and tend to be very brittle. then there are two straps that hold the fuel tank up you must remover two bolts should be 14mm but don't hold me to that. now remove upper hoses and lines. and take the fuel tank out. once out remove the ring around the sending unit/fuel pump. the assembly will come right out. compare pumps to make sure they're the same and just remove and replace. then put it all back together. WARNING** the retaining ring around the assembly may be rusty and brittle so be gentle***
good luck
Aug 27, 2007 at 8:03 PM
