93 LE BARON GTC heater core replacement
1993 CHRYSLER LE BARON
WASS1967
edit! Do not listen to the guy below. he is wrong on how to do it.
Oct 28, 2007 at 5:46 PM
BLACKOP555
  • 10,386 POSTS
you cant just loosen the dash you have to completely remove it all you should see when your done is the steering column and the wires coming from under hte dash. you need to get a clear shot at the air ducts to change it dont worry it is a 3+ hour job to get it apart just keep goign
Oct 28, 2007 at 8:35 PM
WASS1967
edit. Because you edited my post. People should be warned if someone gave false info.
Oct 29, 2007 at 6:13 AM
BLACKOP555
  • 10,386 POSTS
yes but worth it. Better then paying 400-500 for service charge at a mechanics. there should be no hidden bolts and screws.
Oct 29, 2007 at 9:07 AM
WASS1967
Edit due to false info given. And I also deleted my explaination and photos on how to do it right.
This guy does not know how it was done. Should of kept his mouth shut.
Oct 30, 2007 at 6:41 AM
BLACKOP555
  • 10,386 POSTS
You have to take off the steering wheel and pull it off then take the door off of the heater core compartment unconect the hoses from the firewall in the engine and pull it out
Oct 30, 2007 at 8:43 AM
