1993 Chrysler Le Baron Uneven Braking
1993 CHRYSLER LE BARON
CM3150
Brakes problem
1993 Chrysler Le Baron 6 cyl Front Wheel Drive 133000 miles
I test drive the car and the right side rotor is significantly hotter than the left. The car does not otherwise handle improperly. I have changed both calibers and the master cylinder with no change. Anybody have any idea what may be wrong?
Jul 16, 2009 at 10:09 PM
BILLYMAC
  • 2,204 POSTS
Hi normally this will be a bad ruber hose at the caliper..
the other possibility is a bad proportioning valve. the rubber hoses are the cheaper of the two.
good luck Billymac
Aug 9, 2009 at 9:03 PM
