1993 Chrysler Le Baron How hard is it to replace the serpint
1993 CHRYSLER LE BARON
CUTTER
Other Category problem
1993 Chrysler Le Baron Engine Size unknown Front Wheel Drive Automatic 45,000 miles
How much does a serpintine belt cost? How hard is it to replace a serpintine belt?
Dec 5, 2007 at 8:59 AM
MANDERS272
  • 4 POSTS
It depends where you are getting the belt from. they can range anything between $30 to $100. On a Labaron you'll find the belt on the left side, you have to loosen the it first than hold it loose while you slip it into place. goodluck
Dec 12, 2007 at 2:47 PM
