1993 Chrysler Le Baron coolant spewing from transmission?
1993 CHRYSLER LE BARON
99,999 MILES • 6 CYL • FWD • AUTOMATIC
PBUDZY
  • 8 POSTS
ok so I have this car that runs great, and I was told that there is a coolant tube under the intake that goes bad in these 3.0 mitsu engines. However after removing the intake upper and lower I find a large tube that the small tube goes into...do i need to change the whole huge tube in the valley there or am i missing something. original problem has coolant comming out of what looks like the side of the transmission.
Apr 6, 2010 at 10:33 PM
PBUDZY
  • 8 POSTS
The vehicle runs fine ...i wont let it get to temp or overheat but runs great until i turn it off...p.s. there is no oil in coolant or coolant in oil...oil looks great and coolant while it stays in looks fine as well coolant bottle never drops but radiator empties pretty quick when it get a little heat...top of the transmission there are 2 holes that the coolant seems to be spewing from...they are maybe a 1/4 inch holes and I wouldn't beleive them to be freeze plug locations....please help!
Apr 6, 2010 at 10:50 PM
PLOPPYSATOR
  • 23 POSTS
Your problem describes a leaky water pump, as it gets worse, the longer you wait, I am sure, you either sold the car or replaced the pump already
Oct 20, 2010 at 3:33 AM
