1992 Chrysler Le Baron Stuck seat
1992 CHRYSLER LE BARON
134,000 MILES • 6 CYL • 2WD • AUTOMATIC
DEWLOVER
The motor has quit working on my power seat, and I cannot get it BACK all the way. I cannot figure how to remove the seat either. Is there a way to get the seat all the way back when the motor doesn't work? Or can you tell me how to remove the seat (I can do it then)? Thanks!
Dec 12, 2009 at 10:52 PM
CARADIODOC
  • 34,306 POSTS
There are three motors. I can't remember if the switches are in the door or on the seat. If they're on the door, and only the forward / backward motor doesn't work, suspect frayed wires between the door hinges. Peek under the seat and look for the three electrical connectors plugged into the motors. Unplug two of them, switch them and plug them into the opposite motors. If the forward / backward motor runs with the wrong switch, you know the motor is ok. At least you can move the seat now.
You can do the same test if the switches are on the seat. If one of the up / down functions doesn't work now, you'll know the front / back switch is the problem.
caradiodoc
Dec 14, 2009 at 9:05 PM
