1992 Chrysler Le Baron intermittent transmission problem
1992 CHRYSLER LE BARON
67,000 MILES • 6 CYL • 2WD • AUTOMATIC
ABRGET
My teenage daughter's '92Lebaron convertible runs great. Problem recently is hearing a whine and then the cars transmission just quits. Sit for a minute or two and it works just fine. Down the road a mile or two and the same problem occurs. There is fluid in the trans. Any suggestions?
Thanks,
Tony
Jan 14, 2008 at 5:44 AM
MERLIN2021
  • 17,250 POSTS
When you say the car just quits, is the engine shutting off? or just can't move, with engine running? Check on the tranny control for two relays, make sure they are good!
https://www.2carpros.com/forum/automotive_pictures/62217_Trans_Control_1.jpg
Is the check engine light on?
Jan 14, 2008 at 8:27 AM
ABRGET
Engine keeps running fine. Shut it off for a minute or two, car goes like nothing happened. When trans quits it won't work until engine is turned off.
Jan 15, 2008 at 5:10 AM
