1991 Chrysler Le Baron transmission lock
1991 CHRYSLER LE BARON
54,000 MILES • 6 CYL • 2WD • AUTOMATIC
RICHARD3RD
my car is stuck in low gear. I cannot start the car because the shift leaver is in the low gear position. It will not move back to park or any other position.
Oct 20, 2009 at 6:39 AM
DOCFIXIT
  • 18,828 POSTS
Check for linkage bind at transaxle. Remove cable see if you can hand shift into park ect. If yes then shift cable suspect believe floor shift take a look maybe somethinfg got in there and is binding.
Oct 20, 2009 at 7:18 AM
