1991 Chrysler Le Baron 1991 Chrysler Lebaron Noise After At
1991 CHRYSLER LE BARON
JBELCOURT
Noises problem
1991 Chrysler Le Baron 6 cyl Front Wheel Drive Automatic ??? miles
Long story short, I had a small oil leak from the oil pan. I bought a gasket for the pan and when I tried to remove the pan, there where two brackets preventing me from getting to some bolts. One by the starter (a heat shield a believe) and one behind the transmission pan (another heat shield I believe). The one by the starter, I could NOT get off. I tried impact wrenches and everything and couldn't get the bolt off. This prevented me from dropping the oil pan completely, therefore I couldn't re-seal the pan and its leaking bad.
The bigger issue is the bracket that was behind the transmission pan. When I removed it, it was holding in place a thin sheet of metal that went over an opening (to the transmission???) which was right against the far corner of the oil pan and directly behind the transmission pan. The thin sheet was bent out, it appears the previous owner just hammered it down and re-bolted it. Now, when I start my car, it sounds like a Honda Civic when you put a tipper on the exhaust pipe. I don't know if something in the transmission knocked loose and that's causing the noise or what. I attempted to put a piece of thick furniture pad between the thin sheet and the outter of the opening to see if it was just rattle but the noise is still there. It gets louder when I accelerate and such.
Any suggestions would be GREAT! PLEASE HELP!
Thanks,
-Jamie
Feb 17, 2009 at 8:06 AM
I believe the plate is the inspection plate. Behind it is the flywheel. It spins when the engine is running. Make sure the plate isn't touching it.
Let me know what you find.
Mar 17, 2009 at 8:51 AM
JBELCOURT
[quote:e1a6b0b086="Jacobandnickolas"]I believe the plate is the inspection plate. Behind it is the flywheel. It spins when the engine is running. Make sure the plate isn't touching it.
Joe[/quote:e1a6b0b086]
Friend of mine that works for Greenway Ford checked it out for me and fixed that but I have a bad bad oil leak. It looks like its coming from where the inspection plate is though and I'm not sure what that would be??? (rear main seal?)
Any ideas?
Mar 17, 2009 at 9:05 AM
If that is where the leak is coming from, it sounds like the rear main seal. What was causing the noise?
Mar 17, 2009 at 10:15 AM
JBELCOURT
[quote:cb5cb5140c="Jacobandnickolas"]If that is where the leak is coming from, it sounds like the rear main seal. What was causing the noise?[/quote:cb5cb5140c]
Flyl wheel was hitting the inspection plate I assumed to begin with because I was trying to take my oil pan off and I had a co-worker helping me who got under and started muscling stuff off and bent the plate by accident. Friend put a rattle sheet between the bracket and plate and noise stopped.
I was afraid it was the rear main seal. I hear is an expensive and pretty difficult fix. I've been driving it like this, just keeping a close eye on the oil and also tried a container of Lucas Stop Leak.
Mar 18, 2009 at 8:55 AM
