No power to fuel pump
1990 CHRYSLER LE BARON
ALEXANDER3002LA
So I changed the fuel pump before I tested it. The old one worked but I cannot return the new one. After testing both fuel pumps I realized that there is no power going to the fuel pump. What can I do? Is this common for this car?
May 5, 2010 at 1:39 PM
BLUELIGHTNIN6
  • 16,542 POSTS
It sounds like the fuel pump relay is not working. Here is a guide to help you test it and the location of the relay below:
Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed.
Cheers
May 5, 2010 at 6:40 PM
ALEXANDER3002LA
Six cylinder front wheel drive automatic.
I replaced the fuel pump in my car and the new one is not sending gas to the engine. The engine will not turn over.
Jul 19, 2018 at 12:48 PM (Merged)
INTERNETMECHANIC
  • 700 POSTS
Because I do not know testing you have done, I have to start from scratch. If the vehicle cranks good but will not start, have a helper crank it, while you visually check for spark at the plugs. Check for possible trouble codes, if you have not already. To check for mil codes, you turn the key just till the dash lights come, no further, cycle the key on--off, on--off, on, then the mil starts flashing, you count the flashes to get the codes. Your looking for two digit codes. The information I looked at was Lebaron--3.0 sedan. The ASD relay sends voltage to several circuits including the fuel pump. Did you check voltage and ground for the fuel pump motor at the pump connector? The voltage wire for the pump shows to be dark green with black tracer.
STEPCHILD
  • 6 POSTS
for the past three to four weeks my car has been giving me fits. When I turn the ignition key, I will normally hear the fuel pump prime. It now only works randomly. I have replaced the fuel pump relay and the pump itself (boy, that was fun), but still no joy. When I turn on the ignition and hear the pump, it will start. But, all too often, I do not get that beautiful hum that will allow me to go where I need to go. Any help?
Start by testing the ignition switch and the ASD relay.
STEPCHILD
  • 6 POSTS
Thanks for the quick response.
Where would I find the shutdown relay? I cannot seem to find it in any literature I have on the car. And, everything else functions normally when the key is in the start position, is there a direct link from the switch to the fuel system relay?
Thinking there may be a bad or corroded connection at the fuel relay, I sprayed a little WD-40 on the relay and the relay/fuse block, which helped, but did not fix it. I am going to remove the relay block and check for rusted or corroded connections.
STEPCHILD
  • 6 POSTS
I checked the relay block and the ECU connections as well, all looks good. What are the chances that the engine control unit itself is bad?
One more observation, it seems to start best in the morning and evening when it is cool. Springtime here in VA.
The ASD relay is in the engine bay forward of left strut tower. See picture below. I do not know about the computer yet. Check basics before you go there.
https://www.2carpros.com/forum/automotive_pictures/12900_asd_5.jpg
STEPCHILD
  • 6 POSTS
Although the picture is not representative of my particular model, (1992 convertible) I did find the ASD relay and checked it with multi-meter. Seems to be functioning fine. Any other suggestions? By the way, I really do appreciate the help.
What kind of reading did you get from the ASD relay?
FISHES8
I ran out of gas on the way to get fuel. I put a few gallons in and it registers eighth full. Car still will not start. I can hear the fuel pump. I checked i have fuel pressure in the fuel rails (I do not know the exact pressure). I did not get spark at the plugs, so I checked the coil . No spark at the coil. I suspect i may have blown an inline fuse someplace but I cannot figure out where it is. I have Chrysler repair manuals, but ironically I cannot find anything about fuses.
JAMES W.
  • 2,394 POSTS
Running out of gas will have nothing to do with losing spark. With the key on, do you have power to the positive side of the coil?
STEPCHILD
  • 6 POSTS
I do not know how they are numbered, but the pin that is flat compared to the others, had 0 volts in the off position and 13.8 with ignition on.
FISHES8
It is entirely possible that the car developed some electrical anomaly at the very moment my car was on vapors. During my web searches (before I narrowed it to spark) I did happen across a forum post (another site) that said it is possible that a relay, fuse, etc. may have been tripped because of the extra draw from the fuel pump running dry.
The other thing I learned from all of this was that many fuel pumps are cooled by the fuel, so never let it run dry or you might be looking at replacing the fuel pump! Okay, so lets forget that I ran out of fuel. I am trying to find out what could cause no spark from the coil (assuming the coil is good).
Have the computer control of the ASD relay tested.
JAMES W.
  • 2,394 POSTS
It is true, fuel pumps are cooled by the fuel in the tank. GM and Chrysler are not noted for burning out a pump on an empty tank, but Ford is notorious for it. We cannot "assume" the coil is good, we need to know. With key on check for power on the positive side of the coil. If yes, check for positive voltage on the negative side. If no, the coil is bad. Next you need to check for injector pulse. This can be done with an "incandescent" test light connected between both terminals of a disconnected injector connector and cranking the engine. You are looking for the light to blink. If no blink, it is either the crankshaft position sensor or the ECM. The coil and injectors get the signal to fire from the ECM and the CPS.
STEPCHILD
  • 6 POSTS
Turns out the ECM has a physical crack. Replaced the module and all is well. I have my little red mid-life crisis back to par. Thanks for the help.
FISHES8
I replaced the coil because it was only $20.00 and it had some corrosion. I also replaced the ignition relay on a whim because I thought it might have been related to the automatic shutdown (ASD). It also was cheaper that a new ECM. I tried testing for pulse with a multi-meter. It just went from 9 volts to 6 volts during cranking. The book said it should wiggle back and forth. Is a test light more accurate?
What is the crankshaft position sensor?
JAMES W.
  • 2,394 POSTS
Yes, an "incandescent" test light or an analog volt meter works the best. If you are using a digital meter, it will not respond quickly enough. The "wiggle back and forth" is the needle on an analog meter. The crank shaft position sensor, CPS, tells the ECM when to fire the plugs and the fuel injectors. Also, there is a unit called a "noid light" that is a small zenon bulb that plugs directly into the injector connector and flashes like a timing light. You can get a complete set at most parts stores for about $20.00.
BOOSTING16PSI
V6 3.0 Convertible. Battery cables are corroded green with white powder. Need to replace complete positive and negative cables, can they be special ordered? Now not getting power to fuel pump. Would bad battery cables stop just the fuel pump from getting power? Thanks a lot.
Get the battery and cables squared away then check for power at the fuel pump connector dark green and black wire.
BOOSTING16PSI
I finally got the new battery cables installed.The Chrysler dealership discontinued the factory positive and negative cables. :( I had to get the three wire positive cable from Ac delco, but the negative cable was incorrect, it only had two negative wires, body and ignition wire. But every 1992 V6 Lebaron I have seen has three negative wires.Body, engine, and ignition ground. I had to fabricate my own negative cable. I used a Chrysler universal positive battery cable from AutoZone, also replaced fuel pump relay,fuel pump, and fuel filter. Charged the battery and it started right up! Drives better than ever! Faster start ups and shut downs, more power, less hesitation, smoother auto shifting, and better gas mileage! Now all I have to do is drop in a manual transmission and engine with 64,000 original miles and then get ready for Forced Induction (Turbo Charge).
BLAZE1253
Six cylinder two wheel drive automatic.
Hi, when I start my car and it runs for about five seconds and then shut off. This happens after I washed my car. Before it happened but no water got into the engine at all. Luckily it shut off on me in my drive way. I replaced the fuel filter thinking that was the problem it was not. My father and I checked if it was not getting any fuel and it has fuel and the spark plugs work and it is getting plenty of air. So our only solution is the fuel sensor is shot or damaged. We have no idea where it is located and I do not know if it is even the sensor that is damaged.
CARADIODOC
  • 34,306 POSTS
The only thing we know for sure is you replaced the fuel filter. Other than the diesel trucks, you will never solve a running problem on a Chrysler product by replacing the filter. They pass the largest volume of fuel during coasting. Logic would dictate the filter cannot be plugged if the engine runs at all, and washing the car does not lead to a plugged filter.
No idea what sensor you are referring to. If you have spark, the Automatic Shutdown (ASD) relay is turning on. That is proof the optical pickup assembly in the distributor is working. The ASD relay also sends power to the injectors, and the fuel pump or pump relay.
Since you cannot see the fuel spray from the injectors in the V-6 engines, the next step would involve teeing in a test port in the fuel supply hose to measure the pressure. You did not list the mileage, but if it is high, and if fuel pressure is acceptable, I would suggest checking the timing belt next.
If it runs for a few seconds every time you start the engine, that leaves out the timing belt too. That is the typical symptom of the anti-theft system is activated. Not sure if that was an option in 1987.
caradiodoc
