1990 Chrysler Le Baron leaky oil on engine
1990 CHRYSLER LE BARON
150,000 MILES • 4 CYL • 2WD • AUTOMATIC
E.R.FINN
I have an oil leak on the front of the engine.I have had some work done with the crankshaft seal replaced and the leak still persist.I had the engine steamed cleaned and with the vechicle ilded their is no visial leak,when i drive 1 mile then i check the engine the leak gets oil on the front of the engine around the distributor in the middle of engine. I cant see where the oil leak is comming from. please give me a clue what it might be.
Jun 4, 2008 at 4:42 PM
BMRFIXIT
  • 19,053 POSTS
Is the leak around the oil filter area under the distributor
check oil pressure switch disconnect the wiring plug and check for oil in it
replace if oil found in the connector plug
Jun 13, 2008 at 8:33 PM
