1990 Chrysler Le Baron 1990 Chrysler Lebaron Wiper/Washer S
1990 CHRYSLER LE BARON
125,000 MILES • 6 CYL • FWD • AUTOMATIC
LADMAN24
  • 4 POSTS
I have a 1990 Chrysler Lebaron, and it seems the connection of the wiper/washer switch is not engaged all the time. If you use the waser portion, the dash needs to be pulled slightly down at the same time for this to work. Also, the wipers sometimes do not park unless unless you pull down on this area of the dash as well. When the dash is diassembled, the wiper switch becomes disconnected from the wire harnes and the wire plug remains in the dash. Is there any way to remove the wire harness from the indash position and possible zip tie it to the switch for a better connection? Or do I continue to pull slightly on the dash and replace the switch when this no longer works?
Jan 18, 2010 at 8:25 PM
LADMAN24
  • 4 POSTS
Dielectric grease was of no help with the connection.
I will try to tweak the "posts" on the switch ever so slightly so it will make a more snug fit in the connector. I will let you know if this helps.
Jan 20, 2010 at 7:17 PM
BUDDYCRAIGG
  • 2,262 POSTS
I hope messing with the connection helps.
but in my experience, if the grease doesn't fix it, then you have to replace the switch.
BUT... i've never seen the "pulling on the dash" thing either.
so you might be in your own personal twilight zone.
Jan 21, 2010 at 12:59 AM
LADMAN24
  • 4 POSTS
It seems tweaking the connector posts for the washer porion of the switch worked. The posts are made so that they can be seperated somewhat in three. Just be carefull not to over do it or there is a risk of breaking part of them off.
The posts for the washer portion of the switch are quite large in comparison to the minute connectors for the rest of the switch.
One of these larger posts must be the ground connection in order for the circuit to be completed. I do believe it is the ground connection that these switches operate.
Jan 22, 2010 at 8:48 PM
BUDDYCRAIGG
  • 2,262 POSTS
so is it working?
Jan 30, 2010 at 1:38 AM
LADMAN24
  • 4 POSTS
Yes, as I mentioned in an earlier reply, the switch is now working after tweaking the connections so they made contact.
Jan 30, 2010 at 7:32 AM
BUDDYCRAIGG
  • 2,262 POSTS
OK, just wanted to make sure that everything was all good.
Jan 31, 2010 at 12:45 AM
