1989 Chrysler Lebaron Leaking oil.
1989 CHRYSLER LE BARON
SMOOCHES_BABE
My 1989 Chrysler Lebaron is leaking alot of oil. I put about two quartz in it every two days. It just started doing this after I got the oil changed in it. What do you think mibht be wrong with it, and how much do you think it will cost?
Aug 12, 2007 at 11:03 AM
CANADIANAPPRENTICE
  • 18 POSTS
Where is the leak, the V6 model's are notorious for leaking.... "we refer to them as bleeding 3's"
locations of leak.
---> Oil filter loose or double gasketted
---> valve cover seals
---> Rear main seal- between motor and trans
---> Camseals right on the top of the motor.
---> into the motor via valve seat seals...
if there is alot of carbon deposits on your tailpipe, your burning oil, considerable amounts.
Aug 27, 2007 at 8:15 PM
