1988 Chrysler Le Baron ignition switch
1988 CHRYSLER LE BARON
EYBERGD
1988 Chrysler Le Baron Two Wheel Drive Automatic
I am unable to turn ignition with current key and switch, I have a new ignition switch/key, but how do I get the column cover off and old ignition out??
Dec 29, 2008 at 10:13 AM
Hi:
You need to remove the steering wheel and part of the steering column to access the switch. Because of the air bag, I would recommend having it done by a trained tech. If you do it, be careful and make sure that you leave the battery disconnected for at least 15 minutes before starting the work.
Mar 17, 2009 at 10:26 AM
